A discussion thread about Windows 10 for audio and whatever.
Automatic Upgrade Of Older Operating Systems:Windows 10 is coming, whether you want it or not, it's being put into the Windows Update pipeline as an "important" update in 2016. If you have your updates set to automatic you'll get Windows 10. If the upgrade version of Win10 setup is silent or if you don't participate in setup you will get the default settings which turn on the data reporting features' of Windows 10.
Microsoft wants to compete with Google,
selling your personal info personalizing your web advertisements. This is why they are giving it away for free. They do want to wash out older OSes to reduce the support costs, but mostly to pump up their targetted-ads business as fast as possible.
Instead of setting Windows Update to fully automatic, I keep it set to "notify me when updates are ready," then I manually select which updates I want to install. Updates I choose to not install I set to "hide" so the rejected updates don't keep trying.
How to Stop Windows 10 from Spying on You:http://www.rockpapershotgun.com/2015/07/30/windows-10-privacy-settings/
