Anyone else interested in demoing the dspMusik with their GR-Research LS-9's? I have one system that can be sent for trials.
I need at least one person in the Continental US that wants to demo it so I can verify the digital crossover is correct. I have no way to test it here with speakers. If you are in the MD, VA or DC area, I can setup a demo with your system.
This will be the full HAL MS-3 and dspMusik demo system with TRS to XLR cables, as changes may need to be made and much easier using the Audio Weaver development system on the PC to change things if needed. I just email you a file to load as needed.
So far each demo has been done that way in every system. It is very easy to use and comes ready to play your files with Foobar2000. Just hook up a display, USB drive, keyboard and mouse to the front USB ports and the dspMusik to the back USB port. Connect the XLR connections to source and amps. Then you are ready to play music. If you need single ended connections, I can send TRS to RCA adaptors to use your RCA interconnects.
You can demo the system for 2 weeks to give you time to evaluate the sound quality. Just ship it back to me after the demo time.
