Author Topic: Looking for right angle power cord for apple tv  (Read 17979 times)
djdube525
« on: December 26, 2013, 01:35:47 PM »
I need to fit an apple tv on one of these little above the fireplace ledges... the standard power and hdmi cables stick out too far.
finding a right angle hdmi cable or adapter is not an issue... the dang power cable appears to be.
I believe I'm looking for a iec-60320-c7 right angle cable...
I'm not finding what I'm looking for on Amazon, or monoprice... I think I found one, but not too sure of the site.
Suggestions are much appreciated.
Regards,
Dave
Re: Looking for right angle power cord for apple tv
« Reply #1 on: December 26, 2013, 01:56:23 PM »
Dave,
I've purchased a bunch of adapters for my audiodharma Cable Cooker at stayonline.com. Very fast shipping too...
Perhaps you're looking for one of these... http://www.stayonline.com/detail.aspx?id=11843
Good Luck,
Pete
« Reply #2 on: December 26, 2013, 02:36:36 PM »
Hey Dave!! How's everything? How'd the move go?
djdube525
« Reply #3 on: December 26, 2013, 03:04:03 PM »
Dave,
Good Luck,
Pete
That is soooooo close... the way the right angle comes out to the side, it would block the HDMI connection... I need for it to come up... not to the side.
I will check out stayonline though...
FWIW... struck out at RadioShack (don't they always carry this kind of odd ball stuff?)...
Folks at Apple were a bit stumped.
djdube525
« Reply #4 on: December 26, 2013, 03:05:14 PM »
The move isn't official yet... although enjoying the new area while we're in temporary limbo. :thumb:
djdube525
« Reply #5 on: December 26, 2013, 03:06:59 PM »
I suppose I could use something like this with an extension cord... would prefer an all in one cable though.
http://www.stayonline.com/detail.aspx?id=19427
« Reply #6 on: December 26, 2013, 03:37:51 PM »
That's good. Will you be back in NC again, or just staying there?
http://www.vpi.us/pwr-115pc7-d.html
http://www.stayonline.com/detail.aspx?id=26555
Found these googling "C7 angle down," "IEC320 C7 angle down"
Good luck!
djdube525
« Reply #7 on: December 27, 2013, 06:51:19 AM »
That's it (stayonline link)... you are the bomb Rich! Ordering it up as we speak.
I'll be back during Feb for sure (3 week course at work)... still unclear long term.
Dave
« Reply #8 on: December 30, 2013, 05:41:27 AM »
I have the same issue with my Plasma. The AC cord it came with has a right angle like the one you purchased, but it is such a light weight cord that I know my picture quality is suffering. But at least it works.
