I've jumped into the SEOS project with both feet. I participated in the initial group buy for the fiberglass iteration of the SEOS. Here's a couple of links that deal with the design and the group buy.
http://www.avsforum.com/avs-vb/showthread.php?t=1291022http://www.diyaudio.com/forums/group-buys/166312-waveguides-horns.htmlI'm also participating in a group buy for AE woofers.
http://www.avsforum.com/avs-vb/showthread.php?t=1363566The AE group buy is taking longer than expected to complete. You have to be patient in almost any GB situation. It took quite a few months to eventually get the SEOS 18 waveguides.
Of course I'll need compression drivers to power the waveguides so I'll either participate in a GB for the DE250 or try a CD that is being designed by participants in this Zilch legacy project.
I'll also need an active crossover.
http://www.minidsp.com/.
In addition, a mic and software (REW or something else) will be required.
I hope I'm not getting in over my head. I'll have to spend the time necessary to tackle the learning curve to master the DSP. However, I think that this project will allow me to get superb sound without spending $$$. The first listening impressions of the SEOS 15/DE250 have been very positive. Here's a quote off the AVS forum
"Also, I went over to Bwaslo's house on Sunday to look over some other parts and projects. His SEOS-15 speakers with the 15" A&E woofer were completed. I can say without a doubt that these were the cleanest sounding speakers I've ever heard. Most of my listening has been done with dome style tweeters, but I have heard some Klipsch horns and things like that. But nothing quite as big as the SEOS-15. Super smooth, super clean, and I'm guessing they can handle a LOT more power than you'd need in a home.
What really surprised me was how how loud they were without me actually realizing it. The sound was great and I guess because it's so clean you don't realize the volume? Or is that what they mean by a "non fatiguing" speaker? While listening, I said something to Bill in a fairly loud voice, only to realize I needed to raise my voice a lot more than I thought to get over the volume of the speakers. In other words, they were much louder than I perceived them to be. I was really impressed and now my goal is to get a pair built for myself using the SEOS-12."
Sorta reminds you of the initial reviews of Geddes speakers, eh?
18” SEOS waveguides $350 max ...group buy
compression drivers ~$250 or less.
top quality 15" woofers ~$480 ..group buy
miniDSP $120
mic and software $150+
+materials for cabinet (mostly bass bins)
Probably about $1500 total plus my labor.
Subwoofers are mandatory so I should factor that into the cost. I already have a couple of subs so that wasn't an issue for me.
You'd easily be able to build a pair for less using cheaper woofers and the less expensive waveguides that will be available in future group buys by the same group. I feel that this group buy group will become more and more efficient as they gain experience and the waiting times will become much shorter. As it is, it's a good deal and a number of people, especially Erich H (AVS forum) are committing their time, uncompensated, in the spirit of DIY and many will reap the benefits.
...Roy
