allenzachary
« on: June 06, 2011, 06:17:36 AM » |
What .giffs with my animated avatar not animating? it runs on my PC but not in AN? Any clue as to what I'm doing wrong?
az
Logged
« Reply #1 on: June 06, 2011, 06:24:33 AM » |
The forum software reduces oversize images to fit the avatar size limitation automatically. Reducing it kills the animation.
Logged
allenzachary
« Reply #2 on: June 06, 2011, 06:28:02 AM » |
So how do I get it to work?
Logged
allenzachary
« Reply #3 on: June 06, 2011, 06:33:09 AM » |
Never mind...
What do you think?
Logged
« Reply #4 on: June 06, 2011, 06:58:03 AM » |
I think it is still not working...  If you make it small enough it will work Yours works if I open it in another tab. So I think the avatar resizer is still getting you. I don't know what the max avatar size is. There is also a file size restriction, set by admin. Yours is a photo with lots of frames so it could be too large file size. Just guessin.. http://www.simplemachines.org/community/index.php?topic=354497.0
« Last Edit: June 06, 2011, 07:04:39 AM by richidoo »
Logged
allenzachary
« Reply #5 on: June 06, 2011, 08:06:39 AM » |
Weird. It worked for a while...now it's not. mysterious.
Logged
allenzachary
« Reply #6 on: June 06, 2011, 08:08:37 AM » |
Reloaded it and it seems like it's working again.
Logged
« Reply #7 on: June 06, 2011, 09:52:30 AM » |
Still not working here.. Can anyone else see it?
Maybe it is cached in your browser?
Logged
bpape
« Reply #8 on: June 06, 2011, 10:59:30 AM » |
I'm not seeing it.
Logged
AcidJazz
« Reply #9 on: June 06, 2011, 11:57:37 AM » |
I'll toast to that....  Some of those animated thingies can be tiresome...dunno if yours are but generally. What happened to your nice fuzzly grizzly? Did Mama Grizzly clamp down on his public exposure?
« Last Edit: June 06, 2011, 11:59:13 AM by AcidJazz »
Logged
inamorata your music unknown known life....
allenzachary
« Reply #10 on: June 06, 2011, 12:18:12 PM » |
It was a an elephant seal. This should be an elephant on a trampoline.
Logged
allenzachary
« Reply #11 on: June 06, 2011, 12:24:16 PM » |
I cleared cache...it went away. I re-entered the url...it's a 1000 x 100 gif image. I can see it. Can anybody else?
Logged
« Reply #12 on: June 06, 2011, 12:26:13 PM » |
No, but I'll check it out when I get a few...
Logged
« Reply #13 on: June 06, 2011, 12:45:56 PM » |
I tried it and it worked. The 100x100 pixel file is only 33.2KB.
I PMed the one I used to you. Probably same as the one you tried...
Logged
allenzachary
« Reply #14 on: June 06, 2011, 01:45:00 PM » |
how now?
I can see it. Canoe?
Logged
