Fellow Audiophiles,
When I go to favorite used record store (Infinity Records on Long Island), I always clean the used LP's with my Disc Doctor record solution.
Recently I picked up some nice NEW 180 gram Vinyl LP's from Elusive Disc. I was once told it was a good idea to clean them to remove the "mold release compounds" from the pressings.
On the Mo-Fi inner sleeve info, it says "Once the master lacquer is finished it is then plated in a specialized process that protects transients in the modulated groove. Due to this process, there may be occasional pops or ticks inherent in the initial playback, but as the disc is played more, a high-qulaity stylus will actually polish the groove walls and improve the sound".
Should I clean my new vinyl? Thoughts?
Pete
