squeezebox SUCKS BIG TIME
Started by rosconey, December 04, 2008, 09:31:40 AM
rosconey
nope its a straight up pause-says on the remote
it also has a strange shutdown procedure -if you do it wrong the remote goes into search mode and you have to remove the battery to get it to stop-
Make sure you download the latest firmware and software... for the Duet, remote, and slimserver itself.
http://www.slimdevices.com/su_downloads.html
rosconey
says its updated -
it did the pause thing the last time i posted about it happening- :rofl:-i tell you this thing is pure evil-and im not talking the type that jumps motorcycles-
rosconey
guess i still havent figured out how to shut it off-this morning it was all screwed up and wouldnt work
so how do you guy turn yours off?
if i use the remote and turn off the squeeze box then turn off my computer it goes into search mode forever-
if i turn off my computer first the dam thing also goes into search mode :duh
any help?
thanx guys
bpape
Sorry - can't help you - never turn the SB off and never turn my PC off.  Also, I'm using SB's, not Duets.
Hold the Home button down to shut off the remote.
I think there is a command in the remote menu that shuts off the receiver, iirc
rtfm: http://www.slimdevices.com/documentation/WEB_Duet_User_Guide_EN.pdf
rosconey
im starting to get it figured out :rofl:
You'll get it, hang in there. When it works it is a great source, especially with a nice DAC.
rosconey
just got the live music archive to work-
found some big head tod and the monsters of rock -now jack johnson live from Paris-
its still a quirky tempermental sucker :duh
Try the new beta 7.3, supposed to be a good improvement for wireless networking. Let us know.
rosconey
well i just got around to hooking my dac and the squeezereciever to my belkin power conditioner-
it added a bit of focus and db's-had to turn it down a bit-
also bought the hdam module from a ebay vendor to replace the opamps in the dac-not sure what one it is-lol
rosconey
 :duh duet has been a bitch for the last week- i used my laptop on batteries and forgot to switch back to standard power mode from power saver mode-
now its back to be finicky and not unruly :rofl:
Make sure you got that new firmware from SqueezeCenter 7.3.2. That seems to be fixing a lot of problems. Report back if it helps you? Thanks
rosconey
i did the update a few weeks ago i think-
one thing that happened -the local station -never worked-now it does-just not all the local channels
