Author Topic: Checked Your Screws Lately?  (Read 3526 times)
Offline James Edward
« on: January 28, 2019, 03:43:15 PM »
A modification thread regarding my Spatial speakers had me break out the #2 philips screwdriver and check the tightness of the screws holding the drivers to the baffle. Just about all could use some tightening, and some 3/4 to nearly a complete turn.
Not being an anal retentive type of listener, I could not break out the Diana Krall and pronounce mission accomplished, but it certainly can’t hurt to tighten things a bit.
I am also VERY conservative when it comes to things like this; my tightening was done with a light touch. Do they make torque screwdrivers in inch pounds vs the torque drivers I am familiar with in auto work?
Esoteric K-07X
Offline malloy
Re: Checked Your Screws Lately?
« Reply #1 on: January 28, 2019, 07:07:16 PM »
I used to be very paranoid about this. I regularly used to (every month or so) re-tighten the bolts that held the front plate of my speakers (an Epos). I used a ratchet and over tightened the bolts and damaged the front baffle!
But I remember when I did tighten the screws, it seemed to focus the imaging and midrange/treble a bit better.
« Reply #2 on: January 28, 2019, 07:54:24 PM »
I don't know about my equipment, but I have been told on numerous occasions that I have a few screws loose.  :roll:
« Reply #3 on: January 28, 2019, 09:18:33 PM »
The administrator refuses to comment on this issue.....
Glad you’re here, though!!👍👍
Offline dflee
« Reply #4 on: January 29, 2019, 08:13:20 AM »
I'll see your screw tightening and raise you:
Read once that steel screws affect the magnetic drivers and you should change
them all to brass. Well I took one of each size to the hardware store and got all brass
and replaced every one of the steel with the brass. Tightening each snug and excitingly
turned on the stereo. Nada, nothing different audible wise. No better, no worse so I left
em in. They do look cool when the grills off though and don't seem to loosen as fast as the steel.
Haven't had any loosening on any of the electronics but did read in another site about loosening
all the screws helped. Not gonna try that one.
Don
« Reply #5 on: January 29, 2019, 07:36:50 PM »
Don
Don,
I wonder if anyone here has tried that and perceived a difference. If I don’t get an improvement in the sound, then “cool” comes in a close second  :thumb:
« Last Edit: January 29, 2019, 07:38:47 PM by Nick B »
« Reply #6 on: January 29, 2019, 08:58:57 PM »
Don
There was a guy who used to post here that went by the user name Werd that was a big advocate of loosening screws.
Haven't heard from him in close to 2 years now.
Offline Folsom
« Reply #7 on: January 31, 2019, 08:10:13 PM »
My go to, it has a clutch that can go so light you can't even get the screws in!
« Reply #8 on: February 06, 2019, 08:16:58 AM »
   I have tried both ways with screws. Loosened to a snug fit and tightened all the way. Seem to prefer tightened. Appears better focused.
