Author Topic: Door sweep  (Read 9523 times)
Door sweep
« on: February 25, 2009, 08:52:06 AM »
I'm building up my sound room door.. and need a sweep.  They make automatic sweeps that drop down and seal the bottom.. I've seen them before.  Also, I remember seeing some that were made from silicon that were really nice.
My door will be a 1.75" solid door w/ weatherstripping.  It will 'outswing' so it opens out of the sound room.  There is carpet going in the sound room and hardwoods outside.  I was planning on running hardwood under the door halfway into the jam (or jamb?), and then having a wooden transistion strip be the only threshhold.
I've seen these automatic door jams create some nice seals on low-nap carpet... and that's what I'm looking for.. Anyone got any suggestions?
I'm not super concerned about sound leakage... mainly sound quality and keeping external sounds out.
I was also looking at the sound proofing mat here: http://www.soundproofing.org/sales/prices.html
Carl
« Last Edit: February 25, 2009, 08:54:50 AM by Carlman »
Black Sand Cable
Re: Door sweep
« Reply #1 on: February 25, 2009, 09:09:22 AM »
Looking for a door sweep and you didn't ask me? What is up with that?  :)
(Sorry to all who wont get this. It's an inside joke between Carl and I)
Re: Door sweep
« Reply #2 on: February 25, 2009, 09:12:13 AM »
 :rofl:  Yes, is there anything you don't have?
I forget the 'sweeping' array of products you carry.. or have access to.. ;)
Re: Door sweep
« Reply #3 on: February 25, 2009, 11:27:38 AM »
https://www.twindraftguard.com
(not available in stores)  :rofl:
Re: Door sweep
« Reply #4 on: February 25, 2009, 12:52:35 PM »
Drafty basements?  Look no further!  :lol:
Thanks a lot, Rich!
mgalusha
Re: Door sweep
« Reply #5 on: February 25, 2009, 12:56:28 PM »
We had one of these... and threw it out, kept trying to roll under the door. :(
Re: Door sweep
« Reply #6 on: February 25, 2009, 01:55:35 PM »
So, did you have to buy a Snuggie Blanket to deal with the cold? ;)
bacobits
Re: Door sweep
« Reply #7 on: February 25, 2009, 02:38:55 PM »
« Last Edit: February 25, 2009, 02:44:18 PM by bacobits »
Black Sand Cable
Re: Door sweep
« Reply #8 on: February 25, 2009, 03:07:01 PM »
Carl
All kidding aside the stuff in that link would work rather well......but it would take some work to get it on the door right. You would want to create a bulb rubber seal on the bottom of the door. Basically you would take the rubber and staple it to the bottom of the door. When you are stapling you want to make a horse shoe type shape out of it for the bottom of the door. I have done it in the past and it works rather well if you get it right and it will blow the doors off of most standard sweeps.
Re: Door sweep
« Reply #10 on: February 25, 2009, 04:35:22 PM »
http://www.acousticalsurfaces.com/doorseals/adj_doorseals.htm?d=34
The stuff at this link is pretty much what I was envisioning.. thanks, Rich.
Bacobits.. that link to Lowe's doesn't work for me.. not sure if that'd be a better option or not.
The door won't be here for 2 more weeks, maybe more.. So, plenty of time to think about it anyway.
All the other doors and trim get installed tomorrow. :)
