Author Topic: Ribbon Tweeters not working  (Read 12810 times)
Re: Ribbon Tweeters not working
« Reply #15 on: June 17, 2012, 06:39:27 AM »
Thanks for tyhe offer Charles, but I am using my old MTM's. Forgot just how good these speakers sounded, and I'm enjoying the heck out of them again.
I tried the battery to the ribbon trick - NFG. Not even a glimmer of a trickle of a move on the ribbon. So there is definitely something wrong with the ribbon/magnet assembly itself. Still looking for a cause/solution.
« Reply #16 on: June 17, 2012, 06:51:45 AM »
  Bummer about the battery outcome. The Apogees are warm compared to your MTMs I'd bet.
  Are there parts available ?
« Reply #17 on: June 18, 2012, 06:57:59 AM »
Still one or two more tests to run. First I need to completely disconnect the ribbon from the crossover network and rerun the battery test and the continuity test on it. The connected crossover could be giving me a false reading and disguising a break in the ribbon that can be repaired, once found.
All is not yet lost.
Offline StereoNut
« Reply #18 on: June 19, 2012, 06:53:03 AM »
Just be careful Bob...  wouldn't want you to be looking like this any time soon!  :rofl: :rofl: :rofl:
« Last Edit: June 19, 2012, 06:56:45 AM by StereoNut »
« Reply #19 on: June 19, 2012, 08:17:35 AM »
Looks like I should have a gee-tar in my hands.  :thumb:
Offline StereoNut
« Reply #20 on: June 19, 2012, 09:06:41 AM »
Like this?
http://www.youtube.com/watch?v=PF0r-woLbag
« Reply #21 on: June 19, 2012, 01:27:09 PM »
GOT IT!!!!!
At a suggestion from someone over on the Apogee board I disconnected the crossover from the ribbon and checked continuity again. Bingo. The coil across the resistor was masking the break in the ribbon. A few checks with the meter and I fouond where things werentt making contact. A quick patch to the spot that had a micro-break and presto chango. We're back in business again and playing sweetly.
Thanks for all your suggestions guys.
« Reply #22 on: June 19, 2012, 01:38:21 PM »
 :dj:
Offline StereoNut
« Reply #23 on: June 19, 2012, 01:49:23 PM »
You da man, Bob!
« Reply #24 on: June 19, 2012, 03:46:38 PM »
Well done Sir! :thumb:
