Author Topic: Need a power conditioner maven  (Read 30554 times)
Offline Werd
Re: Need a power conditioner maven
« Reply #75 on: November 20, 2015, 09:32:26 AM »
Dave...? yeah Dave. Dave's not here.
Offline Werd
« Reply #76 on: November 20, 2015, 09:41:36 AM »
Somebody should send me one of these Uberbusses to try out. It's got to be in 240V though. I wouldn't deliver a limp 120 to my system and call it a stereo. Same way i would not stand in front of my wife limp asking to get down and dirty.  :D  :thumb:
« Last Edit: November 20, 2015, 09:43:17 AM by Werd »
« Reply #77 on: November 20, 2015, 09:47:14 AM »
Thanks everyone.  I think this is going to be fun again.  :thumb:
« Reply #78 on: November 20, 2015, 09:48:01 AM »
I was, but now out to the shop >>>>>>>>>>>
Offline Werd
« Reply #79 on: November 20, 2015, 10:34:50 AM »
This is the kind of power delivery i expect or it gets boxed and sent back. https://vimeo.com/4366695
Also no nickel plated copper to the outlets or anywhere.
Good Talk!
haha welcome aboard  :thumb:
« Reply #80 on: November 20, 2015, 08:38:46 PM »
Werd,
I must admit, you have a way with "Werds" ba dum!
« Reply #81 on: November 20, 2015, 10:08:09 PM »
Good Talk!
I get it.  Instantaneous and plentiful power with no current limiting other than that inherent in the I/O.
Nickel just sounds bad: thin, edgy and harsh depending upon the resolution of the system.
I chose the P&S 5362A for its mostly brass construction.  They come with steel joining pins in the back.  I pull those and replace them with 6-32x1" brass screws. This leaves the 10-32 neutral crews which I will replace upon request.  One other tweak to the standard receptacle is an option to polish the existing contacts.  All of his makes a killer low cost ($60.00) receptacle.  Cryogenically elated, of course.
