Author Topic: Melody P2688 World Premier Review  (Read 7195 times)
Offline Hugh
    • Angel City Audio
Hugh Nguyen
Angel City Audio
Offline sleepyguy24
Re: Melody P2688 World Premier Review
« Reply #1 on: May 29, 2014, 07:22:51 AM »
What a sleek looking preamp.
Some questions regarding the tubes for this P2688.
From reading the article I found this. "Up front is the full complement of tubes; two 101D directly heated triodes, Melody’s own branded 274B rectifier tube, and two NOS Western Electric 403A input tubes."
Any idea as to why these tubes were chosen? Did Melody want to make a preamp without the more common preamp tubes used? Were these tubes selected because of the cost of this preamp? A lot of these tubes are ones I never heard of other than maybe the rectifier tube and seem quite exotic.
« Reply #2 on: May 29, 2014, 03:24:50 PM »
Offline Hugh
    • Angel City Audio
« Reply #3 on: May 30, 2014, 07:20:47 AM »
The WE tubes are used extensively in Melody product lines.
I believe they decided to use those after doing their research and found the outcome to be of their liking.
Furthermore, their bread and butter PB101 which is their 5th generation since their debut of P1688 about 15 years ago and was voted by 6Moons back then as one of the best is using 6SN7s and 5AR4 plus 101D.
« Last Edit: May 30, 2014, 07:23:24 AM by Hugh »
Hugh Nguyen
Angel City Audio
Offline Response Audio
    • Purity Audio Design
« Reply #4 on: June 25, 2014, 05:46:42 PM »
Congrats Hugh. It is nice to see companies using/doing something a little different once in a while.  :duh
Design Engineer
Purity Audio Design www.PurityAudioDesign.com
Purity Foundation Streaming Pre, Foundation DAC, Purity Foundation Hybrid GaN 200, Pure Audio Project Trio 15 Classic, Sony SACD Player, Nakamichi tape deck,
Offline Hugh
    • Angel City Audio
« Reply #5 on: July 09, 2014, 11:28:06 AM »
Thanks all.
We recently compared it to CJ ACT2 and the CJ owner ended up with his new P2688. :)
Hugh Nguyen
Angel City Audio
« Reply #6 on: July 09, 2014, 06:12:44 PM »
Thanks all.
Congratulations, Hugh... very well deserved!!!
Cool, you must be using the Chinese OCC copper hook-up wire inside the preamp... the best wire in the world!!!  :rofl:  :rofl:  :rofl: Mr. Pu approved!
Cheers,
Pete
Offline Hugh
    • Angel City Audio
« Reply #7 on: July 10, 2014, 06:28:58 AM »
Pete,
How did you know? :)
Hugh Nguyen
Angel City Audio
