...The VR4 mk3 is flattish 4 ohm load. Assume it dips to 3 ohms, but we don't know the phase response of the speaker, which affects the load felt by the amplifier. I did not see a review on Stereophile.com...
Thanks for your input here. As usual, you bring a wealth of information to any thread that you post on.
I believe my VR-4 Gen.III's with the 2012 MOD are different than what the VR-4 Mk3's were. I e-mailed V.S.A. to ask for specs, just to help give everyone a better idea of what my speakers will need to "sing" amp-wise. As soon as I hear back from Von Schweikert, I will post additional info.
SN
Albert Von Schweikert responded to my question on "before and after" specs by saying the specs are really for the most part, the same. The upgraded speakers (2012 MOD) sound better because they have all new and better quality drivers, x-overs, wiring, etc. along with additional cabinet bracing and dampening.
Here's what I found for specs via a Stereotimes review of my speakers when they were new in 2001.
http://www.stereotimes.com/speak101001.shtmlVon Schweikert Audio VR-4 Generation III
3 Way, 5 driver, two-piece stacking monitor
Crossover - 150 Hz and 2.6 kHz.
Response - 20-20kHz, +/- 3 dB, 18Hz-25kHz -6dB (+/- 1dB at midband).
Nominal Impedance - 6 Ohms
Sensitivity - 89dB @ 1w/1m using 2.83v (in room)
Hopefully this helps everyone in trying to match up new electronics to my speakers, so they compliment each other better.
Thanks!
SN
