Another email from Rick with technical measurements and values:
Lots of testing today. Explanations below:
PWFREE - free-air test of the woofer. Fs=41.5hz which indicates their 28hz
claim for bass extension is a little "optimistic"
PUWNEAR : Uppermost woofer measured nearfield. The port contribution won't
show here so the extension is only 55hz/-3db and 41hz/-10db
PLWNEAR: The bottom woofer summed with the port. 48hz/-3db and 31hz/-10db
which is normal given the Fs measurement of the woofer. Not bad extension
but falls short of what I would expect for a speaker at this price.
PONAXIS: On-Axis measurement, mic at tweeter height. The elevated upper
midrange and rising response in the top octaves that I noted in listening is
evident here.
POFFAXH: Response is pretty flat a 30 degrees horizontal off-axis. Typically
this would be tilted downward a little as you move up in frequency response;
however, since the on-axis has a rising response the off-axis has more
energy. In a room with little or no treatment and / or walls that are close
on each side the speaker will sound too forward / bright.
POFFAXV: Vertical response on-axis at 1M. Measured from the top woofer to
about 6" above the top of the cabinet. Very little change at all angles and
shows that the concentric mounting of the tweeter works well.
PIEIM: As expected from looking at the crossover the impedance shows a
difficult load with large phase angles. Given the low sensitivity this is a
pretty difficult load and high current solid state amps will fare much
better than tube amps.
