Author Topic: Negative Ion Generator.  (Read 21044 times)
Re: Negative Ion Generator.
« Reply #30 on: February 06, 2010, 03:01:55 PM »
Does that Agon ad imply that the electronic module inside is available commercially, or maybe cannibalized from another appliance, something available cheap, at Walmart maybe?
rollo, way to take it to the limit!
I like your new audiophile phraseology too. That should be added to the Holt dictionary...
The there is transported to your room.
Offline mfsoa
« Reply #31 on: February 06, 2010, 03:22:07 PM »
That does  it-
My next speakers have to be ruler-flat to 7.83 hz :thumb:
-Mike
Offline satfrat
« Reply #32 on: February 06, 2010, 04:57:34 PM »
That does  it-
-Mike
1st it's the speakers, then you'll be begging Tommy to build you a Cherry SuperPlus Digital amp that'll reach 7.83 Hz.  :rofl:
Cheers,
Robin
Offline RichardS
« Reply #33 on: February 07, 2010, 05:25:52 AM »
Srajan at 6moons recently posted his experiences with this inexpensive Schumann generator (149 UK pounds):
product info here:
http://healingearth.co.uk/TheSchumannResonator.aspx
review here:
http://www.6moons.com/audioreviews/schumann3/schumann.html
Compared to the cables, room treatments and footers/ stands most of us use it seems a fairly inexpensive thing to try....
