I had reached out to MingDa (got a response back from them within 12 hrs
) and here is what they had to say about biasing the amp.
Here is the procedure for biasing MC3008-ABSE after you install a 805 tube.
First, please use the red probe of a multimeter to contact the 1 ohm resistor which is near the tube socket of 805 tube.
Second, please use the black probe of the multimeter to contact the chassis.
Third, there is a 33K adjustable resistor which is round and gold near the tube socket of 300B.
Please use a screw drive to bias the 33K resistor until the multimeter shows 100mA, 0.1V.
That's all."
There is no way I am poking around inside the amp when it is upside down, opened and powered on. I had Lukasz modify the amp so we can use the simple 805 tube without the connection on the top but we were not able to test it due to one of the new psvane tubes being bad (had to wait almost 3+ weeks for replacement to get to me). I have a copy of the updated schematics that Lukasz marked up in case we needed to revert back.
