A very interesting set of tests. I haven't seen that one before. It does make me want to try bupassing the 5.6uF OIMP that I have in my preamp with a .1uF Relcap RT that I have lying around (the survey seems to like those very much). I also used Sonicap Platinums as inter-stage coulping caps in my preamp. I do like this combo very much so am surprised at the relative negative comments for both. Perhaps though, as Dr Loesch found out, using 2 lesser caps in combination with differing strengths and weaknesses managed to bring out the best in both and make for a nice, balanced sound overall. Hmmm?
It also makes me want to pull out the 1.0uF Multicap PPMFX's that I have in my phono stage (bypassed with a .1uF Russian Teflon) and replace them with some 1.0uF Obbligato's that are also in my stash. The Obbligato's are definitely warmer sounding than the Multi's and a tad rolled off to my ears, but could be just the ticket with the teflon bypass.
My phono stage has a switch that allows me to select 2 different sets of output capacitors. I have the following ones on the second switch and they definitely have a sweeter more old world sound that makes some of those hard 70's vinyl records sound just right. They project music in more of a "wholeness" rather than in an audiophile detailed and separated way, if you know what I mean. They are a great PIO cap that was not in the survey, and unfortunately not made anymore so grab em if you see em, are the Amp Ohm's.
